What block will hold 900rwhp ??
Originally Posted by Birdie2000
Bizzzatch, is that over 900 at the tire or the flywheel? Any more info/specs?
Wow, those are very impressive numbers. Especially since without the 200 shot he's still at like 718rwhp, or possibly 780rwhp. Those are VERY impressive numbers for this blower. Heck, I am hoping for that much at the crank in my car with the same blower. Any idea on engine specs, specifically heads/cam? I'm also curious what bottom end he has. Maybe nitrous is in my future as well... lol.
Originally Posted by BlackWidow
Would he be needing to grout the block or will it be strong enough, I didn't know a convetional block could take that kinda bounding?
Madman was making similar power(1200fwhp) for a while in his all out drag 383 LT1 94 TA, and ended up having issues with the bore shifting.
Also heres a twinturbo 383 LT1 that made 937rwhp before the injectors were maxed out.
http://www.augsburg.edu/ppages/~chial/index.htm
meangreen94z I dont remember having any core shift issues. The block is killer and will live. We had some crank failures due to the cog belt on the s/c. The LT1 and LT4 heads suck due to being to thin on the deck surface.
#35
You will need an aftermarket block to hold 900rwp. That is well over 1000hp at the crank. That is serious. Go with a tall deck block and you can use really long rods. I use 6.125 long rods with a 9.3 deck, 4" stroke, and a 1.175 compression height!! Just a thought. If your gonna do it, do it right.
#37
Originally Posted by 96SCTA
Who makes an aftermarket lt1 block????????
I honestly don't believe you have to worry about it.Check this out. Out of the top 3 guys, only the 2nd one specifically states he has a 383 LT1... with 18 psi of turbo blowin'. The 3rd has a 409 and the 1st has a 391.
The 94-96 Impala SS and Caprice 9C1's all had iron blocks and heads. Everyone on the Impala SS forum seems to have either LT1 or LT4 blocks except for one guy who runs a 502 crate.
Anyways, these guys in the 10's (and one in the 9's) are pushing 4200+ lbs of Texas steel down the track. That's roughly 1000 fwhp. There is also another SS out there with a new TT setup, but has yet to be tuned and run down the track due to bugs, glitches and everything else involved in a new extreme project. Whenever it does get fixed up it'll easily be deep into the 9's. Have fun with your project and I wish I could devote time and money (which I don't have) to the same kind of project to my SS.
#39
Chris is currently in the 8s @ ~160mph.
http://www.gmhightechperformance.com.../0409htp_impy/
~1000 fwhp 4 bolt lt1
I dont think anyone has broken a block yet (chris said several times that he is trying) I just think the lack of aftermarket developement is making it a slow process.
