Fuel issue
Old Feb 13, 2020 | 05:34 PM
Travis Conlon's Avatar
Default Fuel issue
K guys I have a 96 z28 with a built lt1 I think my fuel pump is going out but not sure. The pressure at idle is 43 lbs which is right on but when I open the throttle it drops to about 35 psi and stays as long as I’m on throttle. More throttle less psi so I unhooked the vac line to the regulator and used a mighty vac and applied vacuum as soon as any vacuum is created the pressure drops the more vacuum the less psi. Is this right or wrong also I have a dramatic loss in horse power no codes on pc.
