Replacement Harmonic Balancer for 97 Firehawk M6 LT1
Old Apr 7, 2020 | 02:32 PM
prix57's Avatar
Default Replacement Harmonic Balancer for 97 Firehawk M6 LT1
My harmonic balancer will need to be replaced as the rubber is starting to stick out.
I was looking at getting something that's OE replacement and saw on Rock Auto they have ATP 102056 {#12551138} OE Replacement Balancer. It says it has a lifetime warranty so I assume this would be sufficient.
Would there be any other harmonic balancer suggestions or recommendations?
It is for a 97 Forumla Firehawk LT1 M6
Thanks.
Old Apr 7, 2020 | 03:51 PM
Shownomercy's Avatar
Man-Crush Warning
ATI if you want to spend the coin for a good damper.
Old Apr 7, 2020 | 03:56 PM
Vicious95Z28's Avatar
^^^^^this
Old Apr 7, 2020 | 05:19 PM
SS RRR's Avatar
Village Troll
That should work fine. Also, it's a damper unless for some reason your engine has been externally balanced on the front.
Old Jul 25, 2020 | 03:07 PM
prix57's Avatar
I wouldn't mind spending little extra on something better. If there is one that's better quality than OEM and gives a few extra HP with stock setup. Maybe down the road I may do a couple of minor bolt ons.
Is the ATI balancer damper part number ATI 917274 for my application?
I also heard of Jegs & Assault Racing balancers if anyone has any feedback on them.
Thanks.
Old Aug 11, 2020 | 10:37 AM
prix57's Avatar
I may consider getting the Assault Racing ARD 8000170.
https://www.assaultracing.com/item/1...category=62418
It comes with the hub and price is reasonable.
Any benefits to using the Assault Racing balancer / damper over an OEM one?
Old Aug 12, 2020 | 10:13 AM
SS RRR's Avatar
Village Troll
What kind of RPM are you going to be turning and for how long will you be in that upper rpm range? If you are going to be in the 6 to 7K range while rowing gears at the drag strip the one you listed should be just fine.
Old Aug 12, 2020 | 12:53 PM
prix57's Avatar
I won't be pushing it past that. Ok great thanks, I will grab the Assault Racing one then.
Now just to see when this border closure is over to I can pick it up....
