Help! DMF conversation nothing but issues
Thanks
Did your factory dual mass flywheel happen to have any balance weights on it? I ask because many C5s do and if those weights aren’t transferred to the new flywheel and the flywheel isn’t clocked same as the stock, vibrations can and in many cases do occur even with a perfectly zero balanced setup. Basically the old and new assemblies need to be match balanced, where the new pressure plate and flywheel are effectively out of balance to the same extent and in the same place as the stock setup. Again, not sure if this is applicable to a C4 as I know nothing about C4s but it’s worth mentioning.
Judging by your username I assume you have a 383? If so, was it split balanced like stock or completely neutral balanced? The answer to that may help determine root cause.
If you are now using a standard LT1 FW but it is a SPEC and you have a stock bottom end motor than your new FW needs to = that of a stock LT1 FW. A regular store brand one would work. It will have the weight cast in and also have various balance dimples drilled into it. You line up the 6th hole of the FW onto the dowel of the crank or the hole that dowel would be in if missing
What you need to do is have the PP "neutral" balanced. All the clutch kits regardless of brand unless its a original NOS Valeo don't have balance holes drilled in one or more of the 3 ears of the PP. Also original replacement clutches had a paint dab on them you lined up to the dowel on crank but every china clone PP no longer has that as they are not balanced.
Generally this is not much of a problem on stock bottom end motors that are neutral balanced front but external balanced rear vs fully internal balanced motors which have been rebuilt absolutely need a "neutral" aka zero balanced FW & PP
I use a machine shop to balance my FW & PP. Usually costs about $40 or $50
So if that is the case your FW is not balanced correctly. You would need to have that checked but the only way for a shop to know is to have a original one to compare. A cheap $100 stock replacement would work. What I have used a few times and it was plug & play
Driving the car the way it is will kill the RMS...it may even show signs of leaking now.
