High RPM Miss....
have you tugged on/moved the wires going into the 4 pin connector top of opti with the car running to see if the motor stumbles?
confirm all the grounds on DS head near coil are solid (read wire is not broken under insulation near crimp)
Op
have you contacted the ebay guy?
if you sent it back he could test it...assuming his stuff has a warranty
