Throttle position sensor problems after comp cam 306 instal
the only mods Ive dont to my car is comp cam 306, Holley 58mm throttle body, k&n cold air intake, egr and air pump delete, hooker shorty headers, 1.6 rockers, new GM performance timing chain, msd Opti and plug wires, and coolant bypass mod
Between this, the opti and the stalling, it seems to me that it doesn't run fine.
The 306 is a lot of cam for a stock displacement LT1....plus you installed a bigger TB.
YOU NEED A TUNE......NOW!
KW
OR
Just put the stock TB back on. For a cam only, stock CID engine you don’t need a larger TB.
And yes, you need a tune for that sized cam. You can run around as long as you don’t go WOT, but it also may run pig rich.
21 Throttle Position (TP) sensor circuit (signal voltage high)
22 Throttle Position (TP) sensor circuit (signal voltage low)
OBDII
P0121 Throttle Position (TP) sensor circuit insufficient signal activity
P0122 Throttle Position (TP) sensor circuit low voltage
P0123 Throttle Position (TP) sensor circuit high voltage
you need to stop. If the tune is not for a 58mm TB, which you don't need, you will burn up your trans sooner than later.
Even with a tune for the 58 to correct line pressure per throttle blade position most after market TB's need "modification" to work right. This involves either drilling the RIGHT size hole in TB where the Idle air inlet hole is on a stock TB. Don't blindly drill this hole. You need scan software to read IAC counts and take baby steps in drilling to get IAC counts to 32 (30-35) at idle with engine fully warmed up.
TPS on larger TB
slot the 3 holes in TPS so you can "clock" the TPS back so you have about .67vdc blades fully closed and 4.5 vdc fully open
Cam, you need a PCM tune
and if your intake manifold was not machined for 58...that you need to do that also and don't do that wit the manifold on the motor
