24x Firing Order Programmable?
Has anyone had experience NOT hard wiring the LT1 firing order into the PCM?
Been there done that.
No way around hardwiring coils and injectors. Nos 2&3 and 7&4 have to be swapped.
If your wiring harness was from EFI connection you dont need to do anything, they take care of that.
If you built your own harness you should have done this injector/coil swap.
The injector to bank assignment table in the PCM is only used to correct closed loop operation fueling corrections.
