lt1max hp build
Old Jun 3, 2020 | 01:31 AM
jhein's Avatar
Default lt1max hp build
Alright here goes nothing my name is Jon i am building a 1995 lt1 i am going 60 thou over long 3.75 stroke total seal piston rings o ringed block solid copper head gasket twin 56mm turbos and i am trying to find out how far to machine valve guids for .750 lift and if the race springs from ls1 or ls6 will work im thinking of using the scorpion 1.7 offset roller rocker odviously stronger push rods solid roller lifters and probably custom ground cam i have block in for buillet steel splayn caps and i am shooting for 1100 to1200 wheel hp i have built quite a few engines but this is my first turbo build i am going to run forged crank rods and pistons with heavy wrist pin im not much for spelling but if anny one has anny good input on the machining on valve guids would be helpful this is going into a drag car
thanks Jon
