Bad miss under load
Check condition of spark plug wires to see if they are at all cracked or show signs of, they need to be replaced. Start car when it's completely dark. Look for arcing. Give throttle body a few quick blips.
Tick could be a loose spark plug. You can tell if it's an exhaust leak if you put the engine under load at a low rpm and the tick gets louder.
Check fuel pressure without vacuum attached to fuel pressure regulator. Should be between 42 and 45psi. Optimal is 43.5psi.
Usually when it misses under load it's a fuel or spark delivery problem.
Thank you, I’ll check fuel pressure but I’m not 100% that’s the issue the car does run a little rich and will pop and back fire when I downshift coming to a light. But I’ll certainly check it. Now that you mentioned arcing that’s kinda what the ticking sound sounds like. I do have an exhaust leak my header gasket behind the alt failed and this new tick is quieter and doesn’t sound mechanical. My coworker mentioned that the wires probably have a short due to the car sitting through or monsoon season this and last year (I live in AZ so summer storms are not small or light). But thank you again
You may not be able to see the arc from up top. May have to get under car while running to see every plug boot entirely
You have those metal head shields on plug boots?
remove them
If no plug arc, likely Opti issue. Especially if the replacement Opti is not a AC Delco
I'm too lazy to take them all off so I will pull the ends off and use a multimeter to figure out the culprit.
remove them
you were right, I did the plugs and wires today along with the coil on Saturday, still wouldn’t crank up so I replaced the icm today too and it cranked right up, I didn’t hit the oil pressure sender wire and broke it so I gotta replace that too now but it starts and runs I just have yet to see if my misfire has disappeared cuz I’m not driving while it says I don’t have oil pressure
I changed opti, plugs, icm, coil, fuel
pressure regulator, fuel pump
I resistance check the plug wires and visually inspected the wires the best I could (the right side is very hard) and found nothing. I gave up like a year ago. A few months ago I decided to swap the engine I had from my 95TA ( forged 383 with a nice cam and LE2 heads) when I drop the k member and rolled out the camaro engine out the
cylinder 4 plug wire was completely burned through but is was on the part of the routing you could not see.... make sure you keep those wires away from the headers... on my new build I will put insulation sleeves on the ones on the right side that are close to the headers.
any suggestions will be appreciated. I still closing my 385 and should be mounting on on the k member after Christmas
