LT1 swap specifically power steering
Old Oct 13, 2020 | 12:50 PM
goldielocks's Avatar
Default LT1 swap specifically power steering
I am considering putting a 2018 lt1 into my 94 toyota land cruiser. I have read that this particular motor did not have a power steering pump. i'm assuming electronic steering controls. so what are the options available for running hydraulic power steering? TIA
Old Oct 13, 2020 | 08:39 PM
nomoneyz's Avatar
Wrong forum. This is for 92-97 lt1. But to give a little insight. Yes they are electric. There are some companies developing a front runner setup for using a hydraulic steering pump so you can use a conventional rack and pinion or gear box. I cant recall the company name but google should be able to find it.
Old Oct 13, 2020 | 11:13 PM
Catmaigne's Avatar
There are a number of cars that use electro-hydraulic steering, ie the alternator powers an electric hydraulic pump. If you could find one that doesn't need a CAN or VSS input, you could probably make it work. Some Mini's, MR2's, Grand Cherokee's, Subaru XT6's, Volvo V50's, etc.
Old Oct 17, 2020 | 11:21 PM
fex77k's Avatar
I've seen some people use electric hydraulic pumps for cars that don't have room on the motor.
