Pin Driven Optispark Upgrade.
Old Oct 19, 2020 | 02:41 PM
Alejandro Guerrero's Avatar
Default Pin Driven Optispark Upgrade.
I am working on doing H/C for my 1994 Y-Body. The current optispark is spline driven and I wanted to use the Petris Enterprises pin driven opti conversion to change it so I wouldn't have to modify the pin on the cam I am getting. These units are completely out of stock however and I don't know when they will be in. Does anybody know another way of doing this?
Old Oct 19, 2020 | 02:49 PM
atlantadan's Avatar
Modifying the pin is a 5 minute job at a machine shop and is easier than converting to a different opti. Spline to pin drive conversion also requires a different timing cover
Old Oct 19, 2020 | 03:06 PM
Thanks for the reply. I already have a new timing cover, hub, reluctor, crank shaft position sensor et al. to make it work with it. I would like to move to the vented pin driven system. If my opti does go out then I would be stuck with the old system. I also plan on doing a 383 build in the future and would like to keep my cam unmodded so I can potentially sell it for a little more when I move to a bigger one. If you still believe I am better off sticking with the old system however please let me know and I will take it into consideration.
Old Oct 19, 2020 | 08:21 PM
shbox's Avatar
If your cam is stock, it probably has a small hole in the middle of the nose. That won't work with a vented (pin drive) opti. Cam would have to be changed.
http://shbox.com/1/4th_gen_tech2.htm...p_requirements
Old Oct 19, 2020 | 10:26 PM
I am changing my cam as I mentioned in the original post. That is the reason for upgrading to the pin driven Opti.
Old Oct 19, 2020 | 10:27 PM
That link was helpful though, thankyou
