Help with P0011 code
Old Feb 20, 2021 | 03:27 PM
Cainan Kitts's Avatar
Default Help with P0011 code
Hi, I'm sorta new to the LT1 scene. I just got a 96 Trans Am with 50k miles. It has an engine code for ignition too far advanced. I cant seem to find any information on this code for the trans am. Only VVT cars. It has a slight misfire, but runs alright otherwise. I plan on replacing the Coil, Plugs, Wires, 02 Upstreams (just because I like to do thorough maintenance on used cars). Why would I get this code? From what I understand it might have an MSD Opti but I'm not sure. Would this be a timing chain issue or the Opti? Thank you for any help.
Old Feb 21, 2021 | 10:21 PM
shbox's Avatar
P0111 is not listed as a valid code for a 96 f-body. Where did you get this code?
Old Feb 21, 2021 | 10:23 PM
I meant P0011. My bad.
Old Feb 21, 2021 | 11:23 PM
ACE1252's Avatar
There is no P0011 code. The numbering of the codes start at P0100. What kind of scanner did you use to pull the codes?
Old Feb 21, 2021 | 11:27 PM
Innova 31603. I'm also confused
Old Feb 21, 2021 | 11:32 PM
ACE1252's Avatar
I think you need to have a different brand scanner pull the codes. I think Autozone will scan it for free. I'm not sure what scanner they will use, but hopefully it will be a different brand. Are you sure you are using the scanner correctly?
Old Feb 21, 2021 | 11:34 PM
According to my research, the reason this code is so rare is because only 95-96 had it. Apparently it has a crank sensor as well as the Opti. But I'll try another scanner.
Old Feb 21, 2021 | 11:37 PM
ACE1252's Avatar
This code(P0011) is not present in the '96 factory service manual. Simply does not exist for a '96.
Old Feb 21, 2021 | 11:38 PM
This code(P0011) is not present in the '96 factory service manual. Simply does not exist.
Dang. I wasn't doubting you, I'm just saying this is apparently a super rare occasion. That explains why I cant find any information on here though, damn code isn't real. Thanks for the input.
Old Feb 21, 2021 | 11:47 PM
ACE1252's Avatar
No offense taken here. I think it boils down to the scanner not interpreting the codes right....which I've read of several times over the years(from various scanners). It could be other issues.....but I'd chase the scanner angle first.
Old Feb 22, 2021 | 06:10 AM
shbox's Avatar
Innova scanners are known to have a faulty database for our cars. Use something else.
