Recommendations
Old Mar 1, 2021 | 11:35 PM
Mikerruiz2341's Avatar
Default Recommendations
I recently had to pull my motor and get new heads on my 95 trans am
it has a 5.7 with a cold air and some 3in headers and a stage 1 cam I would like to know of any upgrades I could do while the motor is out or should do any recommendations
Old Mar 18, 2021 | 10:13 AM
transam5.7lt1's Avatar
LT1 based on the year? I would start with maintenance items like spark plug and wires, upgrade optispark cap and rotor maybe if you haven't done yet. Reseal what you can on the engine, like timing cover, rear main seal, intake, replace any hoses that may soon need serviced.
Old Mar 18, 2021 | 10:17 AM
SS RRR's Avatar
Village Troll
What's your budget? 3" headers?
Old Mar 18, 2021 | 11:06 AM
fucter's Avatar
clean and/or paint engine bay
delete AC box if you're so inclined
a bigger cam, better heads, new oil pump
Old Mar 21, 2021 | 04:52 PM
nomoneyz's Avatar
What are 3inch headers? What is a stage 1 cam? Actual part numbers and specs would be great as those things you said mean nothing. Are you getting stock replacement heads or ported heads with larger valves? Do you already have the supporting mods for this "stage 1" cam? Is it automatic or manual? What rear end gear?
There is nothing that we can do with the limited information you gave.
Old Mar 21, 2021 | 10:43 PM
Catmaigne's Avatar
I'm guessing he means headers with a 3" collector which sounds like your typical long tubes.
What cam? Assuming you have the supporting mods, some LE heads are probably the next step.
