Need help on my lt1
Old Mar 21, 2021 | 01:17 PM
Lsp Przy's Avatar
Default Need help on my lt1
I spent a lot of money on my motor being built
When I went to the tuner. He couldnt get it to start
till he advanced it to 180 degrees timing and it fired right up...
Does anyone have pictures of how the timing is suppose to be on here and could camshaft be installed wrong??
Old Mar 21, 2021 | 04:46 PM
nomoneyz's Avatar
Your optispark is probably installed off time.
Old Mar 21, 2021 | 06:03 PM
Lsp Przy's Avatar
No opti I have the torque head kit.
Old Mar 22, 2021 | 10:41 AM
Gojira94's Avatar
180* out from #1 TDC/ firing is #6 TDC/ firing. So yes, sounds like cam signal is 180* out. Not sure if/ how this can be rectified with logic or sensor repositioning along with engine rotation on the 24x/ 411 setups. Pistons are in the same place at either #1 or #6 firing, the ignition logic is what makes the difference. If it was a Gen I SBC, the distributor would be pointing at #1 while the cam gears would be at 6 & 12 instead of 12 & 12.
Old Mar 22, 2021 | 11:37 AM
Gojira94's Avatar
I looked at the setup on the Torqhead site. I think all you need to do is bring the motor to #1 TDC, pull the splined or pin drive sensor plate off, rotate the crank 360* and reinstall the sensor plate.
Old Apr 28, 2021 | 06:48 PM
Nick Diaz Jr.'s Avatar
Did you ever get it going? I had issues with my Tune settings and then it ran. I had done a 411 PCM conversion. Took me days to figure it out.
Old Apr 28, 2021 | 07:04 PM
I wonder if the pcm has anything to do with the Torqhead setup?
Old Jul 24, 2021 | 02:24 PM
Lsp Przy's Avatar
Default Not yet
I just started pulling it apart today the machine shop who built the motor has cam gear upside down..... I remember them telling me they dont build fuel injected motors and only have a crab dyno
**** you fastime racing in Taylor mi anyways...
Old Jul 25, 2021 | 12:30 PM
MuhThugga's Avatar
The cam gear gets installed the same way regardless of fuel delivery.
Old Jul 25, 2021 | 02:45 PM
Lsp Przy's Avatar
Default I understand that
im.thinking they didnt give a **** because they were using locked out distributor when they ran it on dyno
Old Jul 27, 2021 | 12:28 PM
Lsp Przy's Avatar
Default I paid someone to do it for me lol this is my prize
Old Jul 27, 2021 | 12:38 PM
Shownomercy's Avatar
Man-Crush Warning
That picture needs the crank gear dot to be of any value.
