Piston recommendations
Question: recommendations on a mid price point forged piston? How are DSS? Using stock rods, crank, all with ARP bolts/ main studs. Thanks!
LE1/cc503 might be a little shy of 400whp without some help. Like a ported intake, larger TB, 1.7 rockers, EWP, high CR, etc. might just barely get you there. I would opt for one of Lloyd's cams though.
I'd suggest a 4032 forged piston if you don't have any plans for spray/boost. The 2618's will be noisier and won't last as long in a street motor. I recommend Mahle powerpaks because they're pretty light and have a thin, more modern ring pack with less friction. I'm sure the DSS stuff would be fine too assuming it's the right alloy (they make both) and reasonably light.
