4-bar Fuel Pressure
Permatex 80019 resists fuel so I use that on any threaded fuel system joins. This is the cure for leaks with this unit. Also works great with water jacket head bolts and trans pressure test ports for trans temp senders, etc.
LU34A calibration summary
Injector Data Sheet: 280-155-868, 34 #/hr Skinny
Fuel Pressure: 44
Flow rate: 35.5 #/hr
Minimum PW @ 44 psi: 729 usec
Offset Compensation versus Battery Voltage:
6.4 Volts: 3105 usec
8.0 Volts: 2046 usec
9.6 Volts: 1521 usec
11.2 Volts: 1204 usec
12.8 Volts: 970 usec
14.4 Volts: 785 usec
15.0 Volts: 752 usec
Short PW Compensation versus Pulse Width:
0.015 msec: -192 usec
0.244 msec: -152 usec
0.488 msec: -109 usec
0.732 msec: -67 usec
0.976 msec: -24 usec
1.220 msec: 0 usec
1.460 msec: 0 usec
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
https://www.thirdgen.org/forums/diy-...bosch-iii.html
Just saw it there myself. I trust that guy. He designed the ECU in my truck.
I'd like to know where they stash their data sheet library...
