Oil leak out of oil pressure sensor / fuel pump sensor holder LT1
Old 08-17-2021 | 09:41 AM
Alejandro Guerrero's Avatar
Default Oil leak out of oil pressure sensor / fuel pump sensor holder LT1
I am having a pretty severe leak from here, I have tried putting oil resistant gasket maker on the threads and oil is still getting out. Can anyone give me any tips to stop this?
Old 08-17-2021 | 03:12 PM
SS RRR's Avatar
Village Troll
You sure it's not leaking out the intake itself? Teflon paste is the best for threads.
Old 08-18-2021 | 01:34 AM
Gojira94's Avatar
I prefer this, threads need to be clean, obviously. I use it on trans temp senders at the pressure test port with no leaks (90-100psi). Teflon pastes eventually harden and get crumbly, even the 'non-hardening' sort I used to use on head bolts.
Permatex 80019
Smoke test to make sure the intake isn't leaking like SS RRR said.
Quick Reply: Oil leak out of oil pressure sensor / fuel pump sensor holder LT1
