Temp sensor moved to pass side, ok?
Old Sep 6, 2021 | 01:49 PM
DrumpJuan's Avatar
Default Temp sensor moved to pass side, ok?
Is it ok to run the 1 wire temp sensor from the driver side to the passenger side? There's a square coolant plug that I dont have a tool for, nothing I have is working, and no one in town has one. If its not a big deal, I will just add wire and route it. Just wanted to make sure it was ok.
This is for a stock 93 Lt1.
Old Sep 6, 2021 | 03:22 PM
shbox's Avatar
Should be fine.
Old Sep 7, 2021 | 02:23 AM
DrumpJuan's Avatar
6 gauge wire ok?
Old Sep 7, 2021 | 08:53 AM
shbox's Avatar
I don't think you mean 6ga - that's huge. The stock wire size is .35mm (22ga).
Old Sep 8, 2021 | 02:39 AM
DrumpJuan's Avatar
Would it be fine with 18? Will it mess the reading up? Make it read high or low?
Old Sep 8, 2021 | 05:56 AM
shbox's Avatar
A larger gauge (18) is fine and won't affect anything. You just can't go smaller.
Old Sep 9, 2021 | 04:56 PM
DrumpJuan's Avatar
Good, thanks
Next question I figured you would have a better idea than me. Im putting an vette LT4 in my 93 TA. Running a vented opti now. I broke a hard plastic line that goes from this red plug sensor to the fuel lines. Can i splice the opti vaccuum line into that?
Old Sep 9, 2021 | 10:23 PM
shbox's Avatar
That looks like the EVAP line. I'd fix it and just rig a tee on a driver side vacuum line of the manifold, if you don't have a port for your opti vacuum.
Stock 95 f-body vacuum setup in link below:
http://shbox.com/1/opti_vacuum_conn.jpg
Old Sep 10, 2021 | 02:21 AM
DrumpJuan's Avatar
Thankyou Shoebox. And your site is awesome.
