Cam Only Firehawk Question???????
Tuning with that 96 OBD2 PCM will be a pain but it can be done. Do not assume you can let it roll without a tune...
I recently found a 96 Formula WS6 (Black w Red interior) that is pretty rare... Its fully built.. Heads,Cam,12bolt and all of the goodies for the suspension... Snap a pic of the Comp TA.. Love those cars... I'll be you stole that thing!!
As already mentioned long tubes aren't bad to do and you'll feel the gains. They will perform even better if you are doing a cam. The cc503 is a good choice. Don't forget about all the extra's. If doing a cam swap you might as well replace the water pump since it's coming off. Be careful with the Opti, valve springs are a must, pushrods, you can keep factory lifters but for peace of mind you are in there so might as well upgrade, timing chain, roller rockers, tuning is a must, all gaskets, etc.... It can be a snowball, but if you can do the work yourself it makes it much more affordable.
https://www.camaroz28.com/forums/exh...0/#post6905815
10/03/08
CC503, 1.6 NSA Pro Mag Roller rockers, PAC 1518 springs, 10* retainers/locks, Trickflow guideplates, 7.2" Comp hardened pushrods, stock heads, stock exhaust manifolds, catback exhaust, K&N CAI, FMS 30# Injectors.
Warmed up:8.882@83.770mph
No full cool down run.
2/19/11
Added Kooks Long tube headers(1 3/4" x 3") and dual cat y-pipe.
Warmed up:8.437@87.88mph
Partial cool down:8.389@88.354mph
