LT1 to 4l60e swap
Hello, I have searched far and long for the info I need so apologies if I missed it. I have a 4th gen LT1 camaro z28 that originally came with a t56. I purchased the car with no transmission and have a 4l60e to swap in.
My question is I picked up a 4l60e that apparently has a LS/Vortec torque converter installed and I would like to find a compatible flexplate for the lt1 that I can mount to the LS torque converter (whatever spacers I need/etc as I think from my research the LT1 has external balancers where the ls is internal). I would rather not go swapping the input shaft / replacing the torque converter if possible as this is just a cheap project.
If I need to drill mounting holes in the flexplate that is fine, but not sure on the rest.
Hopefully this is possible and thanks for your help in advance.
