1995 LT1 Starting, Running and Idling Problem
Old Jan 28, 2022 | 06:42 PM
CodyCamaro13's Avatar
Default 1995 LT1 Starting, Running and Idling Problem
So, I swapped a 1995 LT1 into a 1987 Jeep, took it out and rebuilt it to a 383, big cam, 1.5 roller rockers, pushrods, typical stuff on a decent build. Had a megasquirt installed, had a base street tune put on until i can have it dyno tuned and had it running pretty dang good. Broke some axle shafts rock crawling and parked it for about 5 to 6 months while I saved up to build a better set of axles. Now I'm here and I can't get the thing to start (when it does start randomly, it backfires like an m16 in a war, any sort of throttle its worse, can't rev it unless I rev it slow, cold or warmed up) and I have tried everything and diagnosed everything I can think of. The thing that makes no sense to me, it ran 100% perfectly fine when I parked it and now this. Changed oil, new fuel and even fuel stabilizer, I've checked fuel/injectors, timing, it keeps fouling plugs within minutes and dumps fuel (which helps with the fouling of plugs) I've replaced the opti just to rule it out (have a lifetime warranty) replaced the coolant temp sensor on the water pump, no change, I've taken out and cleaned and even replaced plugs (they just foul within the first few minutes of cranking) checked fuel filter, swapped a coil with a new one, no fuel in the fpr line, still nothing. I'm pulling my hair out, I have an event this coming week. It has gotten to the point now it won't start really at all, it barely chokes.
No I can't data log sadly, I dont have a laptop and the guy that installed my megasquirt never answers his phone. But the megasquirt deletes o2's, map sensor, iat sensor, icm, and I have no smog stuff.
