Overheating problem in 97 trans am
Problem two: I have a misfire in cylinder 2 for some reason and I have replaced the header gasket, sparkplug and the wire. Also, I made sure it was getting spark, which it was. I pulled the second cylinder fuel injector plug out so it wouldn't make more problems and I took off the valve cover to see if I had a stuck valve which I didn't. I am currently out of ideas.
Please help me with this please and thank you
Is the air dam under the front bumper still in place?
Did the thermostat that you removed have a small hole in it to let water through when closed? If there is no hole, then it had the wrong thermostat in it.
Thanks!
Chad
seeyou as an FYI, just because you found it that way doesn't mean it's right. If we tell you that you need a LT1 thermostat, you need to put one in it.
Is the coolant overflow tank constantly filling up or overflowing at times? Does it's level cycle low and high with a cold vs hot engine? Is it leaking or loosing coolant(Is coolant mysteriously disappearing)? Are you having to continually add coolant to the system through the radiator cap to keep the system full?
