Surging Torque converter lock/unlocking?
Otherwise, I will call Dana and see what options for testing etc can be done in this 93 specific transmission. Its a corvette, and even the TV cable adjustment is not like any other with the ASR system.. Its easy, just not the norm..
Closed spark TPS timing to is 34, but right after it opens its at about 38. I think this may be it and the closed timing needs to be raised? or the other needs to be lowered. I can see it fluctuating at speed, as I was trying to maintain speed the best I can.
Tuner has the data. I will see what they say.. Interesting the timing is moving around quite a bit right off of Zero Throttle to 2 then 4 %. It goes up to 6 degrees change rapidly.
So, replaced it, coed is gone. I will redo runs.. Old sensor was 2500 ohms at 70 degrees, 560 ohms at 210 degrees, 9600 at 41.
Here is the chart I used from many years ago to test accuracy. I used an AC Delco this time. Last one was Standard.
*F *C OHMS
210 100 185
160 70 450
100 38 1,800
70 20 3,400
40 4 7,500
20 -7 13,500
0 -18 25,000
-40 -40 100,700
