Freeze plug question
Old Jun 5, 2022 | 04:09 PM
chalou88's Avatar
Default Freeze plug question
Take a look at the attached picture. That is the hole in the block for the water pump drive shaft. Going electric so i dont need the shaft sitting there doing nothing. Is it necessary to plug this hole or can it stay open along with the two below it?
Old Jun 5, 2022 | 05:05 PM
AgFormula02's Avatar
Ok to leave open.
On the cover, a half dollar works in case you have issues finding a plug that fits.
Old Jun 5, 2022 | 09:23 PM
stevo9389's Avatar
Yea you can leave that hole open in the block and JB weld a quarter or a knockout from a junction box or electrical panel into the timing cover.
Old Jun 6, 2022 | 04:21 AM
chalou88's Avatar
Awesome, thanks guys.
Old Jun 8, 2022 | 04:50 PM
Gojira94's Avatar
I see you got your cam installed - which one did you end up choosing?
Old Jun 9, 2022 | 05:49 AM
chalou88's Avatar
Gojira94 I went with the 08-432-8 as it was in stock and ready to ship. Was not interested in the hotcam.
Old Jun 10, 2022 | 08:08 PM
Gojira94's Avatar
Ok, cool. Glad your build is moving right along.
Old Jun 11, 2022 | 07:39 PM
chalou88's Avatar
Thanks man, me too. Well forward progress at least
Old Jun 11, 2022 | 07:42 PM
chalou88's Avatar
By the way i decided not to use the quarter trick and couldnt find a freeze plug that'd fit. So i got a 3/4" long allen head bolt and welded it to a fender washer, with a rubber washer behind that. Inside the cover is another fender washer and a nylock nut. I machined off the shoulder inside the cover with a flap disc
