Intake manifold and head removal
I do have a few questions about this process though. Keep in mind the car has 135k miles on it.
- Should I have them clean the intake manifold and the throttle body while I am there or should I just carb clean the hell out of both and call it a day? I am pretty sure my intake manifold is leaking oil right now so I want to make sure everything goes back together real nice and pretty like.
- Should I get the intake ceramic coated like my headers are?
- Is there a way to get the EGR studs off of the back of the intake?
- I will list my parts below and you can let me know if I am missing something.
- Head Gaskets Mr. Gasket 5716G
- Head Bolts ARP 134-3601
- Intake Manifold Gaskets GM Genuine 12524653
- Bought exhaust stuff for the header install in different thread
- Valve Cover Gaskets Fel-Pro VS50088R
- Throttle Body Gasket GM Genuine 407018
I have had a lot of recommendations to change valve springs and to change valve stem seals. The car does not burn oil right now so my dilemma is that, I change the steam seals and they suck and boom it leaks OR I don't change the steam seals and then they start leaking. This is an iron headed LT1 btw
The only reason I am hesitant to change springs is because this is a stock motor that basically will remain stock forever minus the headers and a tune. Don't want to dump too much into it.
As far as your springs are concerned, it wouldn't hurt anything to at least have the shop test the springs to ensure they still have good pressures, and while you're at it, put on some new valve seals.
Apparently someone on the Impala boards put on high temp sealant on the inside of the manifold and it helped prevent heat soak and gained them .2 seconds in the quarter mile. This guy is pretty legit over there so I believe what he says is true. I figured the ceramic header coating would do the same thing. It is something I have talked about with my coater before.
Ah inverted star good thought, I haven't taken it off so was just hand feeling around back there. I have a few of those and can always use more tools
Yeah that is what I figured I would do is have the shop test them. I will have to order some valve seals.
- Header Gaskets Fel-Pro MS95585
- Header Bolts ARP 100-1109
- Intake Manifold Gasket Fel-Pro MS95580
- Valve Cover Gaskets Fel-Pro VS50293R
- Coolant Crossover Bolt GM 12552974 (I'm sure you can re-use the existing)
- ARP 7/16 Thread Cleaning Chaser ARP 911-0004 (to clean the threads in the block that the heads will bolt to)
I have some header bolts but I do not remember the ARP part number, I believe they are the same as yours although they are a polished look if I remember correctly.
You can clean the intake manifold yourself. Simple Green, brush, repeat as needed. TB ONLY use TB cleaner (read not carb cleaner)
at 135k mi your stock valve springs are beyond done, Replace. Crane drop in kit is long gone. Send Lloyd Elliott a email asking what iron head springs he likes. IIRC Howards??...maybe PAC.
Consider adding 1:6 SA RR...poor mans cam. If using other than 3/8" Crane Gold "narrow body" RR, you will need to trim the baffles, intake side, on VC. Simple mod
absolutely replace valve stem seals. FelPro Viton ones. Most auto part stores have them and doing springs, it's part of that job. Heads off its simple
Coolant bypass, sure, simple mod
replace PCV and the PS hose if original. The insert on DS intake for PCV may aso need replacing if original
Get the Harley rubber washer for MAP
Use Permatex Black Ultra RTV on the china walls for intake. I prefer the FelPro "printo" seal intake gaskets but GM are also fine you got
if machine shop can extract broken iron manifold bolts you can put your stock ones back on. Otherwise go headers which use the other open bolt hole on heads
At this point given heads are coming off have machine shop lap valves assuming no guides need replacing. New valve springs and seals are a must
EGR...well if you insist on removing it, no reason to, than just get the EGR block off plate. Your pcm will need a reflash so the CEL won't come on for EGR delete. EGR has zero impact on performance
I tried getting in contact with LE but never got a reply back, I may hit him up one more time later.
@****** Do you mean Harley like Harley Davidson? That's what I get when I look that up lol
I have FLP headers going on, main reason for this whole exercise. The bolts are broken off in the holes that the headers need.
I just want to take the studs off the back of the intake to use these nicer bolts I have for the EGR. I can neither confirm nor deny that I am removing the EGR
Electro Polished Proformance Single with Damper Valve Springs; 1.265 Howards Cams 98215 | Howards Cams
No question you want to do valve springs and new seals
EGR....with headers and freer flowing than stock exhaust you want the F body 6 speed EGR unless the delete is because headers are non EGR and I assume emission testing is not a issue for you. You would need a PCM program to tune out EGR so at that point get a performance tune, 160 T stat and enjoy the HP gain that, headers and new valve springs will provide along with 1:6 RR
