Spark plug wires & looms help
Guys,
I am getting ready to install the headers on my LT4 and would like to replace plugs and wires while there is some access, I am considering Summit 8.5 wires and need help on looks. What are you guys running for a stock engine with bolt ons?
Vince
Vince
Not sure what you mean by access. You can’t replace plugs with the headers/manifolds not in place because you’ll never get the headers/manifolds back into place due to the plugs being in the way, and you don’t want to risk breaking them by trying to get headers/manifolds in place. You also do not need wires that large in diameter. It will do nothing but create clearance issues between wires and primaries. Just stick with 8mm at the most.
Depends on the headers whether or not they are better reached from the top or bottom. Factory retainers will work fine as long as you do not use 8.5mm wires. 8mm is actually pushing it, but it is doable.
