Need help to source OEM specs cam
I am currently rebuilding fully a firebird LT1 for a swap in a 1970 impala
We had a harness and Pcm made by psi conversion, it will only work with a stock specs camshaft.
Unfortunately they seem to be out of stock everywhere...
Please update me if you know where I could source one for this buid. Having the PCM reflashed for a bigger grind is possible but expensive as I am in Europe
Thanks
