NA LT1 Build?
Old Aug 20, 2023 | 10:25 PM
BodyPillow's Avatar
Question NA LT1 Build?
Wondering if the LT1 can make 700whp all motor? And at what point do I need to start using radials to grip since I'll run my Kumho PS31 for touge and track days.
Old Aug 21, 2023 | 06:37 AM
Epro's Avatar
A quick google reveals a few 396 LT1s in the high 500's
AFAIK, no one has done 700 to the wheels on an NA LT1. Unless you count nitrous.
Old Aug 21, 2023 | 12:25 PM
BodyPillow's Avatar
Then is 700 to the crank possible with a turbo gen 2 LT1?
Old Aug 21, 2023 | 12:58 PM
BALLSS's Avatar
Bad Cherry is a 96 build. Twin turbo, powerglide, Dart block which IIRC is partially filled and runs 8's....but its not a LT1 block
Old Aug 22, 2023 | 01:31 AM
BodyPillow's Avatar
I'm expecting the answer to be no but I'm gonna ask anyway
Can I swap an 5.3 junkyard LS into a 1996 z28 with an LT1 and be compatible with the LT1 harness and ECU? Wiring work and ECU cuts deep into my budget
Old Aug 22, 2023 | 11:09 AM
Epro's Avatar
I believe LS1Tech user "the merv"modified his 1995harness. He did an LQ9 swap.
You'll also need a new custom torque converter if you're reusing your auto (assuming auto) transmission.
Your factory transmission and rear end won't like 700 horsepower.
The $2000 LS swap is a myth.
Hate to be a debbie downer brother, but these are easily answered questions with a quick google.
EDIT: Also you will need an LS steering rack and engine cradle. And an LS intake manifold with LS accessories.
Old Aug 22, 2023 | 06:27 PM
BodyPillow's Avatar
Wish people didn't overpriced their SS's, 20k for a 20+ year old camaro is wild (even if its the top trim).
Old Aug 24, 2023 | 01:56 AM
LTX's Avatar
LTX
it can be done. High compression, big solid roller cam, , 396 and rev the thing to the moon. 7500+
Old Aug 31, 2023 | 09:16 PM
MuhThugga's Avatar
700 is probably possible with the new aftermarket block.
But if you are trying to do this cheaply, then you won't get close.
Old Sep 1, 2023 | 02:11 AM
383z's Avatar
Average 383 makes 450 to 500rwhp. Anything over that will take a lot of custom/expensive parts. Most heads and cam LS7's make 600rwhp, so that will tell you how hard it is to make that kind of power N/A.
Old Sep 1, 2023 | 04:35 PM
SS RRR's Avatar
Village Troll
Not a chance in hell.
Old Sep 2, 2023 | 12:58 PM
LTX's Avatar
LTX
https://www.google.com/amp/s/www.mot...96-gen-ii/amp/
this build was reasonably high for an na build
Old Sep 2, 2023 | 02:41 PM
SS RRR's Avatar
Village Troll
Believable since they are referring to flywheel hp.
Typically, a healthy 396-cid LT1 is capable of over 515 horsepower with a hydraulic roller, pump-gas friendly compression, and a decent set of heads.
Absolutely agree since mine is making right at 440rwhp/500 flywheel.
Old Sep 2, 2023 | 06:22 PM
383z's Avatar
It also has a SBC intake, 13:1 compression, solid rollers, and on E85 with a 58x swap. Thats all out of the norm for 383/396 builds.
Old Sep 3, 2023 | 11:18 AM
SS RRR's Avatar
Village Troll
Way too much time and money for my old, crotchety *** to put into an engine.
Old Sep 3, 2023 | 01:33 PM
383z's Avatar
You're not lying 🤣
Old Sep 5, 2023 | 03:54 PM
LTX's Avatar
LTX
Bad Cherry is a 96 build. Twin turbo, powerglide, Dart block which IIRC is partially filled and runs 8's....but inot a LT1 block
Its 2023 now. Plenty of LT1 factors blocks in 7’s now. 1 in mid 6’s.
