97 camaro turbo?
If you want to go a ltitle cheaper route torqhead sells a complete kit with no rewiring to delete the opti and hook up an LS1 pcm.
EIther case no rewiring needed.
video for third option.
https://www.torqhead.com/shop-24xlin...ody/c/23575138
I recommend just getting regular ls plug wires as the universal wires the kit comes with are... okay ? However you better have the right tools and skill to make them properly or you will have issues.
It sounds like the cost of the torque head conversion which i guess is somewhat mandatory, is about the cost of bits needed for the ls conversion. If you get a gen 4 5.3 all the good parts are already there.
something to consider. Good luck.
I've thought about buying it and restoring or just pulling the engine out to sell.
Couple years ago I impacted used stock head bolts down with used head gaskets then proceeded to drive thousands of miles and made enough power to scatter two driveshafts and two transmissions with twin gt3582s. Only reason I took it apart was I dropped some lifters during a kamikaze cam swap.
Ls motors aren’t for everyone but they are extremely rugged and reliable.
LTX stuff (gen 2) is not so lucky and you will be forced to be creative with how you setup the turbo hotside.
If you are sticking with the LTX, I would slap a stock crank back in motor, good rods and forged pistons with minimal overbore in it. Then slap a 24x sensor array on it, and run the PCM of your choice, either 0411/aftermarket. My vote is Holley, but anything will be lightyears better than LTX OEM stuff.
Realistically, without touching the rest of the car, this is all a pipe dream.
I'm doing a twin setup that keeps A/C and power steering. I've had to do a lot of my own fabricating/creatve thinking already. I've had to stand up the radiator, convert to a Volvo electric power steering pump, relocate my alternator to the driver's side, get a BMR turbo k-member, replace my horns with aftermarket ones and relocate them, relocate my vacuum canister, cut my accessory bracket, and get custom made headers and heat exchangers. And I'll still have to get a shop to do the rest of the hot side, air to water intercooler(s), and charge pipes. With an LSx I'd still have to do some of that like maybe a turbo k-member and stand up the radiator vertically, but the rest would come in a kit.
