Rear end cover bolt thread size and dimensions
Old Jan 17, 2024 | 09:33 PM
LTX's Avatar
LTX
Default Rear end cover bolt thread size and dimensions
Missing a bolt somehow. What’s a good place to get one?
Old Jan 18, 2024 | 08:56 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
5/16-18 x 3/4", nothing special, a grade 5 will do, not a high torque requirement. Anywhere that sells bolts, hardware, big box store like Home depot, Lowe's, Menards.
Old Jan 18, 2024 | 08:57 AM
shbox's Avatar
5/16-18 x 7/8 GM part # 563592 if you want an original. Salvage yard, GM dealer, driveline shop, etc.
Old Jan 19, 2024 | 08:04 PM
Fast355's Avatar
IIRC a Powerglide, TH350 or T400 pan bolt is also the same. Vortec 4.3/5.7L water pump pulley bolt would also work. If you are doing the scrap yard or garage crawl. I like the OE GM trans pan bolts because they are serrated flange heads in many years and help prevent them from backing off. I upgraded my 14 bolt FF to the trans pan bolts and used RTV specific for gear oils and oil pans to keep the cover sealed up nicely. Never will put a gasket on a rear end.
