another newb
Old Jul 29, 2004 | 02:03 AM
97th_sign's Avatar
Default another newb
well just thought i would check out this board, my name is Quentin Andrade...i originally started posting on norcal-ls1/lt1...been on there for bout a year now. i got a 97 t/a with heads, mild cam, moroso intake, 1le elbo, 1.6 roller rockers, underdrive pulley, hardened pushrods, forged connecting rods, SRP pistons, manly valves, underdrive pulley, 8.5mm msd wires, lt4 km, 160tstat, hooker Lt's through x-pipe, 52mm tb, spec stage 2 clutch, LCA's, PHR, polly tq arm bushing and polly tranny mount...thats pretty much it, the car looks stock...so guess i'll be talkin to everyone some more later...oh ya im from cali...
-Q
Old Jul 29, 2004 | 02:16 AM
S8ER95Z's Avatar
Welcome, thats an extensive mod list you have going...any track/dyno #s?? Hope you enjoy your stay here.
Old Jul 29, 2004 | 02:31 AM
Vendetta's Avatar
Welcome to the board! Enjoy your stay here.
Old Jul 29, 2004 | 10:18 AM
Jordan57's Avatar
Dude...that baby is killing me man....welcome
Old Jul 29, 2004 | 12:49 PM
97th_sign's Avatar
thanx for the welcome...as for dyno numbers i have no idea i still need to get a tune done on it...and track numbers i hit a 13.4@106 with a burnt plug wire...lol...kinda sucked cuz 1st gear still wasnt hooking with the BFG drag radials then the 1-2 shift they would break loose again so i dunno what i could hit with good traction...oh ya and the sixties were 2.2...i hope to hit a decent 12 all motor once i get the Lt4 hot cam...
-Q
Old Jul 29, 2004 | 09:45 PM
Jordan57's Avatar
Do not buy the hot cam a.k.a the "not" cam. It is very outdated and for all the noise it produces is not worth it. My suggestion to you if you are going to go with a cookie cutter cam...(read not custom grind)....get the GM 847 cam...its $209 and is a much better choice regarding performance...especially with heads like your car has...a low 12 should be easily attainable and with some weight reduction and a real good 60 12.0s maybe.
Old Jul 29, 2004 | 11:56 PM
97th_sign's Avatar
i have been thinkin about the 847 cam, but i havent heard anything about how its drivability is, since this IS my daily driver...as for weight reduction the only reduction i do is pull the spare tire, jack, tire iron, jumper cables and my tool box....other than that i run full interior, another thing thats killin me is the stock 10-bolt, i havent had the money to upgrade to a 12bolt w/ gears yet so im only launchin the car at 2800-3200 RPMs...anything less it bogs big time and any more the tires spin like crazy...so im still working on the launch. all in all i want to hit 12.5 all motor with full interior, its not an impossible goal but will take some work on my part when it comes to driving.
-Q
Old Jul 30, 2004 | 09:40 AM
Jordan57's Avatar
Well the specs are very similiar to the Comp Cams 306 which I have recently installed in a friends 97 Z. Even untuned his ran decent and its an automatic. The 847's cam has the same LSA...112...a little more lift .580ish and is a heck of a lot cheaper than the CC306. I would say the 847 with a pcmforless tune and/or the tune you already have...if you have one....and that should def put you 12's. Actually your setup right now should be into twelves. You just need a better sixty foot time. Dang those 10 bolts they are crap man...lol.. Good luck.
