new engine
Old Jul 31, 2004 | 11:29 PM
wants2race69's Avatar
Default new engine
hello, my cousin and i pulled his engine and found out that he broke the crank and the oil pump messed up a piston and broke the block where the oil rod is.. messed up the timing chain gears and flywheel and torque converter... the car locked up at 115mph.....needing to know where to get a new lt1 for a good price but good quality with a warranty...long block or short......also his car is a 97 formula a4.......and i have a 96 z28 m6 and wondering if i put an exhaust cut out on my car where would be good and im running with cats...thanks for the help
Old Aug 1, 2004 | 03:06 PM
Jordan57's Avatar
Scoggin Dickey performance sells a new 355 short block for 1795 and a new 383 short block for close to 4000...this is all new mind you...new block and no core charge. All forged internals and choice of compression ratio...not sure on the number off the top of my head....check sponsors>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>over there!!!
For the cut out...put it after your y pipe merges...either after or before the flange to the catback!
Old Aug 3, 2004 | 09:00 AM
Gangly's Avatar
you want the cutout as far down the i-pipe as possible. the exhaust flow will be able to smoothen out in time and exit the exhaust cutout with less turbulanece this way. Most individuals place the cutout right infront of the bend in the i-pipe that goes over the rear axle.
Old Aug 3, 2004 | 10:12 AM
94Formula/TA's Avatar
AP engineering cut my buddy a really good deal on his short block. ->>>>> see ad
