bang for the buck lt1
Old Aug 13, 2004 | 02:55 PM
heinz57's Avatar
Question bang for the buck lt1
New to this board but there looks to be alot of lt1 and lt4 literate people. I am getting ready to stroke (383) my 94 lt1. considering new heads, cam and possible lt4 manifold. Heads i am looking at the lt4 afr 195cc P#1031 heads. wondering if this combo is much better than the 180cc afr heads for the lt1 or not. This is going into a rock buggy with which we go to the sand dunes where i run some nitrous. Any help? Need some cam advice. Going to keep the compression at stock.
Old Aug 13, 2004 | 10:38 PM
Vendetta's Avatar
AFR 195s will flow a lot more than 180s.
Old Aug 16, 2004 | 12:37 PM
heinz57's Avatar
Thank you, I am leaning that way. I am still researching the cam of choice. This in a non-emissioned rig. With the mix of Rock crawling and Sand dunes just trying to get as much cam without loosing the low rpm reliability. Any suggestions?
Old Aug 16, 2004 | 01:41 PM
DietCoke's Avatar
A hotcam or cc305
Old Aug 17, 2004 | 03:58 PM
5432LT1's Avatar
what about the gm 847 grind?
ive heard some amazing things about it..i dont know if its what youre looking for though.
Old Aug 18, 2004 | 10:29 AM
heinz57's Avatar
I will certainly look into it. thanks for the info.
Old Aug 21, 2004 | 09:38 PM
SSPerformance's Avatar
u wana make shure the heads arent to big and match what your doing with the car
Old Aug 21, 2004 | 10:14 PM
METALBEAST's Avatar
I think an LT4 Hot Cam or a CC305 are going to be too mild for a 383. I would recommend a CC306.
Old Aug 22, 2004 | 12:22 AM
Mikey 97Z M6's Avatar
-Is this an auto or stick?
-How often are you actually going to be using the spray? How big of a shot?
-How much hp are looking to achieve?
-Staying with fuel injection or going with carb?
Depending on these answers, you may consider just porting the stock LT1 heads. Well ported LT1's should easily obtain 480fwhp NA on a 383-396 combo with the right cam. Since you want to retain some rock crawling ability, I'd veer away from the large runners of the AFR heads IMHO.
Mike
Old Aug 23, 2004 | 06:57 PM
heinz57's Avatar
Mike
I have been using a 150 shot on the current motor. We hit the sand dunes about 4 to 5 times a year. I burn about a 10lb per day. We do the cinders about 2 time a year, same usage on the nos. I am running a th400 and I am staying with fuel injection. I do run 5.38 gears.
I certainly appreciate your help. My biggest concern is using the fuel injection. I plan on increasing the TB and Injectors and computor work. Any suggestions are most welcome.
Old Aug 23, 2004 | 08:35 PM
You might benefit from a nitrous grind cam then. The larger lsa will make it more drivable in slower, rock crawling situations too. The cam I'm running would easily hit 400rwhp and 390rwtq or so on a stroked LT1. It's a comp cams extreme energy 224/236. The original design was a nitrous grind with a 114lsa but I had mine ground on a smaller lsa <112>. I think this cam would be perfect for your application in it's original configuration. It has a little lope on my stock block, but on a 383 or 396 it wouldn't be bad at all.
Truthfully, I wouldn't even worry about a larger tb unless you're after every last hp you can find. I ran the numbers in my sig with a stone stock, unported tb. Many will argue it's not even needed until you start getting real close to the 400rwhp mark and even then, it's only around 5hp. Hardly worth the 300.00+ bones IMHO.
Judging from the 5.38 gears, I'm guessing you have real large tires, 33"+?
Mike
Old Aug 24, 2004 | 10:40 AM
heinz57's Avatar
Mike
Thanks for the tip on the tb. Can I go wilder than the 224/236 with the fuel injection and still have a decent idle. The guy putting the motor together says if the cam won't make it thru emissions then it won't idle, is this the case? HELP
Old Aug 25, 2004 | 12:46 PM
regorih383's Avatar
Default yayhyayay
the hell with the hotcan,cc306,and the cc305... go with a custom girnd like me
FMS coustom grind .585intake .595ex, 235,242, 112+4
Old Aug 25, 2004 | 03:58 PM
heinz57's Avatar
Ok, this is alot closer to what I was told to get. Are you still running fuel injection. If you are then I could with a little more info push the go button on the heads and cam. Another question is will this idle just ok. These were very close to the specs athough he was talking a little more lift and lsa of 110. I appreciate the assistance.
Old Aug 26, 2004 | 11:43 AM
regorih383's Avatar
im using 30 SVO injectors
Old Aug 26, 2004 | 11:45 AM
regorih383's Avatar
my heads are LT4 and they cam for the the Head god "Flow" in the head division in Heaven :
Old Aug 26, 2004 | 02:21 PM
You can go as big as you'd like to go with the cam. If you want to retain good low speed rock crawling capabilities you'll want to stay a bit on the smallish side. You can always add more nitrous, but it gets more difficult when you put too large of a cam in there to begin with. It's all in what you can live with though.
Good luck.
Mike
Old Aug 26, 2004 | 02:40 PM
heinz57's Avatar
Good luck.
Mike
Thanks again, I am going to downsize a hair and like you suggested go with a tad more nitrous. If someday I feel lucky and win more casino money I can try my luck with more cam.
