LT1 Limits?
Old Aug 18, 2004 | 10:34 PM
MadMike93TA's Avatar
Default LT1 Limits?
Hey Guys.... I'm trying to finish building my Supercharged 383 w/ NOS 93 TA, and I was just wondering how much HP a stock LT1 block can take? AND! Are you better off using the factory 2 bolt main caps with a girdle, or is it better to have it splayed to a 4 bolt? I've heard some people argue about which is really better with no real outcome... thanks guys
Old Aug 18, 2004 | 10:45 PM
5432LT1's Avatar
Curious myself
Old Aug 19, 2004 | 12:27 AM
94Formula/TA's Avatar
You might want to read the topic "what block for XXX horsepower" right below this one. The block will take it. Everyone generally agrees that the splayed 4 bolts are better, when it comes to numbers most people including myself stop talking. I just have no experiance to quantify "how much" better.
Rich
Old Aug 19, 2004 | 12:42 AM
BizZzatch350's Avatar
Moderator
Thats you going to be your limit. Theres a blown Firehawk down here, making 9 some at the wheels, its on a T-trim at 22lbs and a big ol wet shot. Has a LT1 block still in it. RickC5 has a 96 Formula on a 91.5mm, that car really should test the limits of what an Lt1 can take. Couse plenty of guys ave gone 15xmph in the 1/4 with LT1 blocks.
Old Aug 19, 2004 | 08:56 AM
Gangly's Avatar
rick ran in the bottom nines on a wild LT1 with a big shot of gas for a while before deciding to swap to a wilder setup with turbo's. He should be running solid 8's with the LT1 block when he is finished. Shouldnt be too far from now.
Old Aug 19, 2004 | 11:35 AM
Moderator
I heard its some little stuff left to do. But isnt his Throttle body ilegal for Thunder because its not forward facing? That car is going to haul ***, he really wnats 7s out of it.
Old Aug 19, 2004 | 04:20 PM
dhdenney's Avatar
I left the 2 bolt mains in mine. Some old timer once said to me, "Have you ever heard of someone breaking their mains?"
Old Aug 19, 2004 | 10:00 PM
Z284thgen's Avatar
i got my stock 2 bolt main caps in mine but then again i did put ARP main studs in mine when i was building
Old Aug 19, 2004 | 10:55 PM
Joe Overton's Avatar
what limits??? to my knowledge a 4 bolt straight or splayed lt1 block has yet to have a block failure..... only one even close was madmans lt1 and that block broke cause he hit the guardrail and impact hitting waterpump cracked it.... I been wrong before so who knows,but I think parts have failed before the block has ..exception being 2 bolt factory mains which I know have failed...
Old Aug 19, 2004 | 11:15 PM
fastta's Avatar
Yes I've heard of dozens of 2 bolt main failures. So far the LT1 block seems to holding OK behind around 1200 HP at the flywheel. Usually if you plan on making more than that, it is hardblock time.
Old Aug 20, 2004 | 03:49 AM
Vendetta's Avatar
Listen to this guy. He knows his ****.
Old Aug 20, 2004 | 03:28 PM
sounds good to me... i only plan on making close to 900 at the flywheel
