How to spray an LT1
My '96 in sig started out with a 100 wet by way of a fogger just before the TB. That picked me up from 13.7-.8's @ 101-102 to 12.7-.8's @ 109-110. I then upped to a 150 shot, which brought me to 12.4-.5's @ 112-113.
Then, I switched to a CompuCar plate, and with NOTHING else changed to my set up other than getting rid of the fogger, I went consistant 12.0's @ 115-116. Now, ask me if I'll ever run a fogger again.
For the record, at that point my car was bone stock save for a K&N/cat-back.
Jon
COMNBYU - thank you also, good to hear an exact comparison like that.
Thanks for all the heads up on safety stuff. I planned on some of the normal stuff, and things like fuel supply, well lets just say I need to upgrade that before ANY size shot goes on. I doubt the S10 fuel system is up to the task.
I personally, don't want to spray from the MAF b/c it's around the corner from the intake (LT1 is in my S10, and uses an intake hose from an Impala). I'd prefer something to spray EVENLY into the intake. I don't see how that is possible around a bend, or I atleast don't think that's the "best" and safest way to do it.
A fogger pointed right at the thottle body seems like it would be much better.
In my mind I picture either a TB plate, or plumbed throttle body to be the most even spread, aside of a direct port (which then depends on size of shot).
I guess with the amount of spray, and times I will spray, a plate seems to be the best, unless I can find a decently priced oversized TB that's plumbed for nitrous, just incase a later build would benefit from the larger TB.
My intake is drilled for direct port, but I would still need to buy all the distribution blocks, jets, and additional lines. I have a basic NX fogger kit, and the extra nozzles, the rest would be peiced together.
BTW, poll result are closer than I expected. Well, except for Noszzle systems, which aren't for LT1s, but I hadn't really thought about it before posting the poll.
moral of the story TNT Kits are the best LT1 spray bar plate kit on the market IMO.
Does anyone know if the LE3 heads and LE2 cam is a good set up to spray a 100-150 shot on?
i am not saying that it aint effective because I sprayed a 175 wet and picked up 25 MPH in the quarter... so it obviously works, but I would say regardless of the size shot the direct port will be MUCH safer and probably more effective. Now if price is an object I would do the plate kit, because you will be suprised how much stuff you have to have with the DP kit
my .02
From the research that I've done while I was piecing together my nitrous kit and deciding to spray my car -- I found that a lot of people preferred the fogger nozzle over the plate system on the LT1 because the first two cylinders would run a little leaner than the rest because of the TB being so close.
With the fogger it disperses it better before it hits the intake so it will disperse to the cylinders more evenly.
In your particular situation -- because your intake is already drilled for it, I would definately do with the direct port. That'll make sure you've got the same ammount of nitrous/fuel mix per cylinder, and will actually be much safer than any other nozzle/plate system that you would/could run.
You don't necessarily have to have a fuel pressure safety switch, as long as you have a way to monitor your fuel pressure. Obviously you need an adequate fuel pump/system to be able to keep up with it if you do choose to go with a larger shot.
A window switch isn't a neccesity either, but definately recomended. The most important thing (which a lot of people don't do) is to just install it and assume its all good. Get some wideband readings to make sure you're not leaning out too much on spray, and of course find a way to pull timing/get a tune that will work with it as well. Personally I'd rather lose a little bit by pulling too much timing, and ensure a much longer life for my motor.
No kidding! Just reminds me how out to lunch some of the people here are
Punching 200RWHP out of the hole with a Nitro Dave Hidden Direct port and perfect plug burn
plate kit . It looks the best on an lt1 to me
