MSD Question
Old Sep 2, 2004 | 10:42 PM
joshua32's Avatar
Default MSD Question
I am going to replace my ignition coil...should i replace it with a stock one or should i use the msd? Also, do i have to install anything else for the blaster coil to work properly?
Old Sep 3, 2004 | 09:44 AM
TA TED's Avatar
STF Veteran
If I remember right, the MSD is direct replacement, and no noticable HP gains are seen. I've always used the stocker.
Old Sep 3, 2004 | 01:41 PM
biltLT1's Avatar
Only upgrade if you have an MSD or comparable ignition control box.
