Does Nitrous make a pretty big difference on an LT1?
ROTFLMAO
. Wheels up pretty good on this
http://mywebpage.netscape.com/Shawn97Z28M6/Shawn675.mpg
and as far as refilling it...just depends on how often you use it.
My friends have had a mix of good/bad luck. Some friends spray forever it seems...and others get a few passes in because they overlooked something. Good luck..and do your homework on it
As for $$, about $7 a pound give or take. And make sure the refill place uses a filter when filling your bottle. one speck of dirt can clog something up or make a solenoid stick...BOOM!!!!!
Before you even spray, invest in a window switch, minimum of 3000 rpm to 2-300 below your rev limiter. It's cheap insurance. Also call the N2O maker of your brand and ask what spark plug is best, or get on here and ask in the N2O forum
So, If that is your car, you really don't deal with the mediocre street cars, you apparently go all out.
Jeremy
Jeremy,
Until you know a lot more about Nitrous, don't use it. Not being a dick, just trying to save you from hurting your motor.
Now, the dick part: that "somebody" you quoted is either a tard or never really used nitrous (or both).
One night a few months ago I went to the track and clicked off a 12.57 @110 (crappy weather by the way). I went back to the pits, installed my bottle, and waited about a half hour for a little cool down. I turned on the bottle heater and made sure I had ~1000 psi of bottle pressure and then did another pass, spraying "just" a 100-shot. 11.40 @122.
So, yes, nitrous will make a big difference. A difference you will certainly feel. And yes, LT1's love the bottle.
More than likely you need a rebuild before you start to up your car's performance. You can run a compression check on your cylinders, check your oil pressure, even have an oil analysis done, and a bunch of other parameters... but I personally wouldn't be messing with a 133K mile LT1 unless I was deliberately trying to "pop" it.
l
l
l WERD.
Contact the guys at Cold Fusion Nitrous--------------->
They have an awesome custmer service and tech. There are also a few guys from the company on this forum. Go to the N2O forums and they check all the forums and give good advice, "nitrous mike" is one. Don't be afraid of nirtrous, the most important part is fuel. lotsa fuel to not lean out and run a wet system. it's safer for the motor.
