LT1 Intakes
Old Sep 11, 2004 | 02:17 AM
TwoFast4Lv's Avatar
Yes Jeff seems to be the man on that front
That reminds me I need to call that dead beat
Old Sep 11, 2004 | 02:24 AM
S8ER95Z's Avatar
Thanks for the info Fireturd... now is there any real gain?? Its a lot of money for something like that. I wouldnt want to just take a chance on something that costly.
Old Sep 11, 2004 | 12:33 PM
TwoFast4Lv's Avatar
Here is some good reading. Jeff (Hotrodhawk) has had great luck with it.
http://web.camaross.com/forums/showthread.php?t=194309
Old Sep 11, 2004 | 03:32 PM
rdavis93's Avatar
The only reason to go with an LT4 intake is if you are going to switch out to LT4 heads. And the only real reason to switch out to LT4 heads is if you are going to port them. I remember reading-and this might have changed by now-that ported LT4 heads would far outflow ported LT1 heads.
Old Sep 11, 2004 | 06:17 PM
BizZzatch350's Avatar
Moderator
The ported LT4s still flow better, but people that set up LT1 heads right, in good set ups, cars run fast as hell. Look at Steve Quinns car.
Old Oct 27, 2004 | 10:47 PM
Dave95Formula's Avatar
Originally Posted by TwoFast4Lv
Those are some of the options. Ours should see smaller gains but retain STOCK linkages and use slightly modified fuel rail......
I pick-up the fianal version next week. Have to finish up a heads and cam swap on a 396 to test it......
I will let you guys know how the testing comes out. After the Flow testing I already will build the next one a shade different.
Any more details about your intake and the results you had?
Dave
Old Oct 27, 2004 | 10:51 PM
TwoFast4Lv's Avatar
Still working on it. Putting a Distributor hole in it next so I can run a crank trigger distributor and get the High voltage out of the opti No more eating Optis!
Old Oct 28, 2004 | 04:28 AM
dmoor88's Avatar
let us all keep in mind that in order to use an LT4 intake you must have LT4 heads.
Old Oct 29, 2004 | 08:51 PM
Tonyss1's Avatar
Default LT-4X Intake
As far as I know this is the only LT-4X intake Steve Quinn has built.
Old Oct 29, 2004 | 09:50 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
i have done a few ported intakes and sold them, i am pretty happy with mine, nothing like Steve's creation but it works for me nonetheless! i am waiting to hear back from the person i sold my last intake to..i am excited to see what he runs with a set of ported heads as well! i am running .5 sec faster than last year on motor with my modded intake, jesels, and gen 6 dfi being the major changes
Old Oct 29, 2004 | 10:45 PM
flyinZ's Avatar
Taner,if you plan on makin' up anymore LTx intakes, lmk and I'll have ya "work" mine over...I'll put'er to the test..
