Biggest Cam?
Old Sep 10, 2004 | 04:18 PM
Formula96's Avatar
Default Biggest Cam?
What is the largest cam i can put in without having to fly cut the pistons?
Old Sep 10, 2004 | 05:25 PM
mighty mex's Avatar
if im not mistaken...the 306 cm is the wildest off the shelf cam made for the LT1. anything bigger and wilder would have to be a custom grind.
Old Sep 10, 2004 | 05:38 PM
nspr8td lt1's Avatar
gm 847 and cc306 are pretty big. im in the process of installing the cc306 myself.
you can get the 847 fairly cheap from jason cromer. i know someone here would have the #.
Old Sep 10, 2004 | 05:49 PM
S8ER95Z's Avatar
I think its the GM 847. Im not an expert at Cams though...could be wrong.
Old Sep 10, 2004 | 08:45 PM
Formula96's Avatar
I also will be running nitrous and stock ported heads. Do yall know the exact specs for those cams (lift, duration)?
Old Sep 10, 2004 | 09:36 PM
S8ER95Z's Avatar
I found this for the 847 (could be wrong..but I think thats correct)
GM 847
234/242 I dont know the LSA for the 847.
574/595 with 1.6
CC306
230/244 112 LSA
541/576 lift with 1.6s.
Old Sep 10, 2004 | 10:27 PM
TwoFast4Lv's Avatar
I have been running the GM 12370847 for a few years no problems. this cam is also readily available from Crane under there number
I have ran it with 1.6 rockers intake and 1.5s Ext with the Imp. gasket
Edit: See what hapens when you drink and post
Old Sep 10, 2004 | 10:36 PM
S8ER95Z's Avatar
Ah thank god someone knew the number!! You cant find a whole lot of info with just 847. LOL
Old Sep 11, 2004 | 10:11 AM
Formula96's Avatar
Thanks for the info, i plan on having comp cams custom grind me one.
Old Sep 11, 2004 | 04:57 PM
Sunsceamer's Avatar
What are the best springs to run on a 847 with stock heads?
Old Oct 12, 2004 | 03:25 AM
SprayedLT1's Avatar
Originally Posted by TwoFast4Lv
I have been running the GM 12347847 for a few years no problems. this cam is also readily available from Crane under there number
You sure about the part number? I find it listed under part number 12370847
Old Oct 12, 2004 | 09:54 AM
BizZzatch350's Avatar
Moderator
You can go bigger, SAr2Ks cam was a lot bigger than an 306 or 847, these arent LS1s were thats an issue.
Old Oct 12, 2004 | 10:47 AM
-PEPE-'s Avatar
Crane 99893 Springs or their newer set that just came out, will have to get the PN from my book in the car, I'll repost the new PN though, it's just a little beefier spring rate. The 99893's are excellent springs for the 847 and lasted an entire year with 1.7 RRs prior breaking 3 springs and collapsing 1 CompR lifter. I no longer use the 1.7s due to changing out a bunch of junk again they worked good for a year though but the 1.6s are a little less stress on your valvetrain geometry.
Heres the info someone was looking for earlier:
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
$209.00
* Crane Cam 109841 grind # HR-296-2S-12 IG (CAM) $209.00 from Jason
* KM# 16214681 $29.95 from Jason - 96 Corvette 5.7 L w/55 LT4 Knock Sensor
* Crane Kit #10308-1 (SPRING KIT) Includes retainers & locks.
* Crane 99893 - Springs alone.
Old Oct 12, 2004 | 09:01 PM
TwoFast4Lv's Avatar
We have had the BEST luck with K-Motion K-800s on high lift cams like this. The Crane kit started to valve float after only a month and the Comp springs were not happy at all.
Old Oct 14, 2004 | 01:19 PM
Elysian's Avatar
You're planning on running the GM847, ported heads, !AND! nitrous? You don't plan on doing that with the stock shortblock, do you?
Old Oct 14, 2004 | 02:02 PM
-PEPE-'s Avatar
Good point, better not do more than a 75 wetshot....100 at the most....not even sure I'd do either depending on the miles. They Hypershittypathetic pistons won't hold up.
Old Oct 14, 2004 | 05:02 PM
stik6shift93's Avatar
Right now I'm running a cms 236/245 115 lsa cam I don't remember exactly but lift is somewhere around .555/.575 and I haven't run into any issues. I have also run through 2 bottles on a 150 shot without any problems. Chevyguy3 off of here ran a 200 shot on a heads cam stock shortblock. I believe he went a best of 10.55 with a 6speed, he also ran that setup for a while without any troubles.
Old Oct 14, 2004 | 09:53 PM
Quickshotkimber's Avatar
You can go bigger than the 847
Old Oct 15, 2004 | 11:06 AM
Mikey 97Z M6's Avatar
Ellis,
Which comp springs were you running with it? 986, 987?
Mike
Old Oct 15, 2004 | 03:54 PM
SAR2K's Avatar
Arrow
242/252 .594/.612 and had PLENTY of PV clearance with the factory pistons. For the most part LT1/SBC can get away with some pretty aggresive valve timing thanks to the standard reliefs... poor LS1 guys are VERY limited with their true flat tops from the factory.
Remember that the MAIN issue in piston to valve is cam timing not gross lift #'s.
Steve...
