Afr 227
Old Sep 21, 2004 | 11:06 PM
Schurters LT1's Avatar
Default Afr 227
Just what do people think of the AFR227 heads pro/con's of them on a 383....and DD car....
thx
Old Sep 22, 2004 | 10:20 AM
-PEPE-'s Avatar
excellent head choice for a decent stroked bottom end 396/408, 383 would be a little mild for those heads unless it had a really agressive solid cam and all the boltons, upgraded fuel system, intake, etc.
Old Sep 22, 2004 | 12:24 PM
Vendetta's Avatar
a friend of mine used them on a 383 with a big shot of N2O and put out great power... that's about all the info i have to offer, though
Old Sep 22, 2004 | 05:52 PM
Snow Dog's Avatar
ask joe overton. hes setting records running those heads.
Old Sep 22, 2004 | 06:14 PM
BizZzatch350's Avatar
Moderator
For sure, all in a lil 388 cube motor
Old Sep 22, 2004 | 08:18 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
i like mine as well, they will be flowed and reworked as required over the winter. i am looking forward to that!
Old Sep 22, 2004 | 09:45 PM
Birdie2000's Avatar
Taner, who you havin work them?
Old Sep 23, 2004 | 10:41 AM
RealQuick's Avatar
Is it true that the valvetrain geometry is different with the 227's versus typical LT4 style 195's, 210's ? Just wondering because i thought i read a post where you need to run shaft mounted rockers with the 227? Can anyone shed any light on the subject?
Old Sep 23, 2004 | 10:49 AM
Joe Overton's Avatar
Shaft rockers are not required and will take some mods to make them work somewhat...227's are made to work with conventional stud rocker assemblies...
Old Sep 23, 2004 | 10:59 AM
METALBEAST's Avatar
So would 227s be advantageous enough over say AFR 210s to justify the cost and the time to modify them?
Old Sep 23, 2004 | 11:04 AM
metal tough to say...I bought my heads as file cores and they were completely hand ported .... Afr's flow numbers are lil higher than they actually are per thier website depending on what bench they are flowed on I guess... 210's 227's I'd look at .200-.500 lift numbers and see which is better then make a decision if using thier CnC services ...
Old Sep 23, 2004 | 11:10 PM
Joe would these heads work on a DD car..as into big...
