How do you tune a 1996 LT1?
Old Sep 23, 2004 | 01:21 PM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
Default How do you tune a 1996 LT1?
How do you tune a 1996 LT1? Tunercat only list up to 1995. I know the makers of LS1Edit has a version for LT1s but it is quite pricey.
Thanks, Becky
Old Sep 23, 2004 | 04:35 PM
SAPPER's Avatar
If you want to do your own tuning then LT1edit is the best out there, IMO. But if you want a custom tuning, there are many sources available. Hypertech, superchips, and some others offer a hand held unit that installs a preset program and will allow you to make minor changes to rev llimiter, speed limiter, correction of speedo for tire sixe change or gear ratio change, fan initiation for cooler t-stat, etc.
Another way to go is to have the PCM flashed (reprogrammed) by a facilitator. This is where you get the most form flashing the PCM. they will flash the pcm for every bolt-on you have. The con is that you cannot make any changes yourself and it stands as is. One faciltator that I use and, IMO, is the best tuning and the best price is www.PCMforless.com Bryan Herter will do your programming and is very good at what he does. You might want to check his site because I think he is going to NC for a Dyno-tune for a club there. Also, he has available, if you have a laptop, at least a P133Mhz, you can load your own that he will e-mail to you. The programming is $50 (load yourself) $95 for the cable from a separate person (AKM cables), and $25 if you want lifetime free updates for any changes you make. Or you can do a PCM exchange. But for $170 and updates, you can't beat it.
Old Sep 23, 2004 | 07:14 PM
Snow Dog's Avatar
switch back to OBD1 and use tuner cat. thats another option. but im not sure what kind of emissions you have to go through
i will be switching back to odb1 and using tuner cat on my 96
Old Sep 23, 2004 | 10:42 PM
This is for a customer's car. I tune LS1s with Edit and HPtuners, but I have never done anything with LT1s. So it still looks like LT1Edit is still our best option. Thanks guys for the input.
Old Apr 28, 2022 | 10:06 AM
Rbwin96Z28's Avatar
Default Lt1 tune
[QUOTE=Snow Dog;1803769]switch back to OBD1 and use tuner cat. thats another option. but im not sure what kind of emissions you have to go through
i will be switching back to odb1 and using tuner cat on my 96[/QUOTE
What do you need to do in order to do that? Do you need to switch the harness back to obd1 harness? I have a 96 and I swapped my engine with a 95 so now think I need to flash and program the obd1 pcm to get it to work, just want to make sure I know how to do it properly before I do anything drastic.
Old Apr 28, 2022 | 11:09 AM
Ls7colorado's Avatar
Might wanna start a new thread, this one is a couple years old, im pretty sure though if I remember right from my LT1 days all you need is the computer and maybe the knock sensor are different? I dunno, google will tell you...
although the engine is identical from 95 to 96
Old Apr 28, 2022 | 11:17 AM
SAPPER's Avatar
WOW! I was a 5 month member when this thread was first posted.
Old Apr 28, 2022 | 03:50 PM
Z28Roxy's Avatar
An 18 year old thread bump? Jesus.
Old Apr 28, 2022 | 03:52 PM
SS RRR's Avatar
Village Troll
All you need is the OBDI PCM and an OBDI knock sensor.
