CompR Lifter Adjustment??
I personally have found the best way to make a LT1 quiet is to install Isky adjustable giude plates and center the rockers on the valves. LT1s have a slightly different valve spacing then standard SBC heads and like this setup to run the rocker best.
Good luck!
Good luck.
