Anyone have this problem with Hooker LTs?
Old Sep 27, 2004 | 01:54 PM
FIREHAWK #7's Avatar
Default Anyone have this problem with Hooker LTs?
Put my Hooker Lt's on my 96 LT1, about 3 months ago, and when i take off from a dead stop it sounds like they(the LT's) are bouncing or vibrating off some thing else like the k member or ?
Anyone ever had a similar problem Thanks!!!
Old Sep 27, 2004 | 02:42 PM
-PEPE-'s Avatar
look real close at your pass side header where the primaries come down by the K-member. They could be just touching right there with engine vibration. Some ppl grind the Kmember a little in this area.
Old Oct 2, 2004 | 02:34 AM
regorih383's Avatar
Default d
ya i had a problem with a hooker onced too. i had to slap her 2 get her to come with me
Old Oct 2, 2004 | 03:12 AM
TwoFast4Lv's Avatar
Yes if the Y-pipe is not built right it will do this. I have also had a early set hit the K-member on the Pass side
Old Oct 2, 2004 | 04:57 AM
DietCoke's Avatar
Check clearance with the steering shaft as well
Old Oct 3, 2004 | 09:56 AM
TWS's Avatar
TWS
Check the steering knuckle. I installed my JET HOT LT's early this year. They are basically a copy of the Hookers and my steering knuckle was touching the primary tube. I got out a dremel and ground the flanges on the knuckle down a little bit.
Old Oct 3, 2004 | 09:20 PM
5w20's Avatar
Maybe it was faulty installation.
Old Oct 4, 2004 | 09:25 AM
dhdenney's Avatar
I have the same problem but I don't really care about it. I assume when the engine moves/car flexes that the headers do hit the K member but that's only on take off. With my steering knuckle, there was direct contact when I installed them but I just took a ballpeen hammer and made me a dent in the primary for clearence. Works like a charm.
Old Oct 5, 2004 | 06:35 PM
Mike454SS's Avatar
Maybe your engine mounts could stand to be replaced?
Old Oct 5, 2004 | 09:02 PM
Default hooker lts
I know its not the y pipe b/c its also a Hooker y pipe, everything matches up, i'm guessing its the k member. will check it out tomorrow. What do you guys reccomend shaving the k member, or bending the LT's?
I think I will bend the LT's.
Old Oct 6, 2004 | 09:39 PM
5w20's Avatar
Bird-O i wouldn't bend those long tubes, i would rather do something about that K-member...just put rogers shorties
Old Oct 6, 2004 | 09:41 PM
regorih383's Avatar
Default Get back
Old Oct 7, 2004 | 12:41 AM
Default hiroger
U R A MORON!!!! this guys 383 "Stroker" mad 360 ponies to the wheels, your car sux
Old Oct 7, 2004 | 06:46 AM
OneMeanZ's Avatar
Had that problem, except my Jet-Hots were doing just more than touching, I couldn't get my knuckle back on unless I dented the primaries
Old Oct 7, 2004 | 09:35 AM
-PEPE-'s Avatar
sheesh I wasn't expecting to read this at 9:30am ...totally took me by surprise.
Old Oct 7, 2004 | 10:42 AM
5w20's Avatar
U R A MORON!!!! this guys 383 "croker" made a mad 360 ponies to the wheels, your car sux
<---- He will be doing this when he gets "b00sted"...
This will be in his pants nice and warm ---->
owner of the red formula ---> <--- owner of the red hatch
Old Oct 7, 2004 | 01:04 PM
regorih383's Avatar
Old Oct 7, 2004 | 01:07 PM
regorih383's Avatar
Old Oct 7, 2004 | 01:10 PM
regorih383's Avatar
were is the oil man <-------There he is
Old Oct 7, 2004 | 02:09 PM
5w20's Avatar
the "handa" will get you and leave you like this ---->
= roger 383 croker
<--- Thats you at the starting line on regular radials because of the 10 bolt.
Don't worry when you lose you can still with me....
