lt1 clutch help!
Old Oct 7, 2004 | 03:32 PM
12stones's Avatar
Default lt1 clutch help!
my buddy has a '93 z28. he just replaced his clutch (himself) and he had the flywheel resurfaced. he got everything back together fine, and it works fine but he says it has WAY to much chatter. he didn't replace any of the hydrolics. then we looked up on mitchel on demand and it said do NOT resurface the flywheel. does anyone know indeed if your not to resurface the flywheel? also would this cause the large amount of chatter? could you just tear it back down, replace the flywheel and everything be fine? oh btw this is a factory replacement clutch, car has about 70k on it. thanks for the help
-Jim
Old Oct 7, 2004 | 06:36 PM
BlackWidow's Avatar
-Jim
My 97 has chattered from day one GM says some of them just do that I say BS. I replaced my clutch with a centerforce dual friction and didn't surface the fly wheel and I still have chatter unless I am in on the clutch pedal. I have been told that it could be a throw out bearing the tranny was sent to D&D in mchigan and they said nothing internal was wrong. So I hope maybe the throw out may be bad.
Old Oct 7, 2004 | 10:09 PM
TwoFast4Lv's Avatar
ALWAYS resurace IF it is not to warped. Any time you cut a LT1 Wheel there is a chance of chatter
BTW what clutch did you use?
Old Oct 7, 2004 | 10:47 PM
12stones's Avatar
well its not my car but i beilve he said he just used a factory replacement
Old Oct 8, 2004 | 09:34 AM
TA TED's Avatar
STF Veteran
Had mine cut and never had a problem. I used an LT4 clutch that time.
Old Oct 8, 2004 | 12:59 PM
97LT1's Avatar
I went from stock clutch in my 97 to resurfaced stock flywheel + spec stage 2 with no chatter.
Old Oct 8, 2004 | 02:23 PM
12stones's Avatar
so what could it be, possibly a throwout bearing? i'm not sure but i dont beilve he replaced it. and i know he didnt replace the hydrolics
Old Oct 9, 2004 | 01:49 AM
Y2kHawk05's Avatar
I have a 93 Z, replaced the clutch with a McLeod clutch & throwout bearing, and a new OE flywheel all myself. No chattering problems. Believe resurfacing is always a must if you do not replace the flywheel. I find it hard to believe the new factory clutch package did not come with a throwout bearing part as well.
Old Oct 9, 2004 | 12:49 PM
97LT1's Avatar
Yeah the clutch is supposed to have a new throwout with it , usually. Maybe slave causing problems. Good idea to change slave while your doing clutch. Your positive the clutch disk is in correct and not backwards?
