picking up my lt's friday
Old Oct 11, 2004 | 07:31 PM
gabeg94z's Avatar
Default picking up my lt's friday
i am picking up my lt's friday but am wondering what i might need to get good sound and performance , also i plan on dumping the exhaust before axle so as far as mufflers what else do i need or what should i get, open for ideas
Old Oct 11, 2004 | 07:48 PM
markymark's Avatar
bullet mufflers are the most common and popular for dual exhaust systems on the lt1.....plus they are only like 35 bucks or so each. I have also heard good things about the dr. gas x pipe, which is what I am gonna use come spring as well as the bullets when I do my true dual setup. You may wanna pick up a new set of o2's also, because I have heard of many people and seen first hand from my friend of the o2's going bad within 1-2 weeks of installation of longtubes. Other than that I would say you might as well change your plugs and wires while your manifolds are off and there is room. An lt4 knock module is also something you should install because the true duals and headers may create some false knock. And if you havent had the car tuned yet, then I would highly reccomend doing so.
Old Oct 11, 2004 | 11:57 PM
MA1384's Avatar
I gotta say, the cam did by far the most for sound. I was really surprised with how much of a difference it made.
Old Oct 12, 2004 | 11:59 AM
gabeg94z's Avatar
so from the lt header just add the bullet muffler and i am cool i dont need to add a x pipe or anything, what about an extention from the header and then the bullet muffler. and as for o2's do i get the same kind i have or is there a certain brand i have to get or a certain length
Old Oct 12, 2004 | 06:57 PM
gabeg94z's Avatar
Would I Have Any Problem Running Headers Straight To The Magnaflow Bullet Muffler With Out A X Pipe
