Someone help
We just cant figure out why it would be dumping so much fuel.. even when its running.. you can smell the raw fuel that is being dumped.
This definatly sounds like a fuel isssue. Check the injectors is my best bet.
-Todd
Bad injectors? or bad computer? if the injectors were bad would the car run at all? It definately is a fuel issue.. there is tons of fuel being dumped.. even at idle.
Trying to figure out how i could tell if one was seized open... it smells and runs like its spraying fuel all the time.. also floods out and almost dies when stopping.
good idea.. i didnt know for sure if they would work in the lt1 without a reprogram.. ill try that though.
Have you tried unplugging the maf? See what it does in "speed density" mode. You may have a vacuum leak somewhere... a bad EGR? Unplugged port somewhere... If the 02s are picking up air that hasnt been metered it could be dumping more fuel to compensate and its purposely flooding itself. Just a thought.
right now we're just trying anything we can think of.. lol
If you put different size injectors in the pulsewidths are for the 24lbers (I dont think it "knows" how much its spraying..but more or less tuned for the specific injector.)
So with a 24lber its spraying 70% (just a random number I made up).. if you put 28lbers in, it still thinks it is firing 24lbers and sprays 70%. Which is obviously too much.
This could be wrong... however I believe you need to program for injectors or it doesnt respond well at all.
I do see your explanation..and it makes sense...so I might be completely retarded as well. LOL
about the 94 camaro.. as being discussed in the someone help thread.. well today when we put the ls1 injectors in.. didnt help much.. we took a look at the plugs and found that #8 was covered in oil and grease. not good.. then looked at the plugwires and #8 is burned in 2 places almost in half.. the others just about all of them are burned in at least one spot.. all the way to the core.. you can see the fibers.. The wires are only a month old.. Probably found most of the problem.. Now how do we keep the damn wires off the longtubes?? SPecial wires? special looms or something? Thanks
