need help with a cam question???
Old Oct 26, 2004 | 10:53 AM
regorih383's Avatar
Default need help with a cam question???
i bought a coustom girnd cam which is .585intake, .595exhaust, 235/242 with a LSA of 112+4. here is my question, what does +4 on the 112 mean. and what does this mean when you install the cam? Does this mean i have to install the cam advanced 4 degrees or im i just going to line up the marks form the cam to the crank?
Old Oct 26, 2004 | 12:45 PM
dhdenney's Avatar
The +4 is 4 degress advance built right in. Just line up the marks. The guys at Comp told me that most cams for our car (off the shelf and custom) are all +4 anyway. No special installation necessary. Your cam is similar to mine, what's your cubes? What injectors are you running? I had a post on injectors but not getting anywhere. I'm needing to downgrade and was looking for what size of injectors people had. I had seen both 30# and 36# in 396 motors and was wanting opinions.
Old Oct 31, 2004 | 03:38 PM
5w20's Avatar
He has a 383 on 30# injectors.
Old Oct 31, 2004 | 07:37 PM
96capricemgr's Avatar
The 112 is Lobe Seperation Angle which is pretty typical for LT1s, tighter like 108 would mean a nasty idle with bigger peak numbers, wider like 114 will mellow the idle and produce less peak power but have a wider powerband and is sometimes used to bandaid the selection of too big a duration. The +4 was already covered, playing with that number can affect where the powerband falls too.
Old Nov 2, 2004 | 12:48 PM
regorih383's Avatar
Default efsdf
get off my peace 5w20
Old Nov 2, 2004 | 09:16 PM
qqwqeqwrqwqtq's Avatar
I thought he had a turbo 383?
Old Nov 2, 2004 | 10:35 PM
regorih383's Avatar
Default fsdasd
NO i have the turbo 383 the n/a 383 is my friend , thats his build up
Old Nov 10, 2004 | 10:30 PM
5w20's Avatar
You have a 383 N/A.
Liar....just because I'm building something with boost now you all up on da nutz ....You and your wet dreams of boost (yet you don't know anything about it).....Look and learn boy!
Old Nov 10, 2004 | 11:23 PM
https://ls1tech.com/forums/10-second-club/208513-turbo-lt1-10-90-145-25-a.html
Old Nov 10, 2004 | 11:40 PM
5w20's Avatar
He does this too much , just like that. He calls them his ballbats....
Old Nov 11, 2004 | 10:52 PM
97M6Formula's Avatar
Oh yeah well then me and Jim(intmd8) raced last night and I beat him with my quad turbo big block 2800lb fbody but only by one car length or so....
And to the cam question what those guys said are on...I just ordered a custom grind kinda like that...its 236/245 114lsa .569/.580
