1995 Formula Help!
Old Nov 8, 2004 | 09:31 PM
v8fbf702's Avatar
Default 1995 Formula Help!
Whats up i have a 1995 auto formula (lt1). Couple days ago when i took her out for a spin, car made strange noises. Whenever i get to about 4500 RPM's, the car will start making a lot of popping noises (a couple per second) and then will stop after it shifts. Whenever it looses a little bit of power. Any suggestions??
Old Nov 9, 2004 | 02:58 AM
LT1 Guy's Avatar
Are there any other problems that you are experiencing associated with the popping noises?
Old Nov 9, 2004 | 09:51 AM
Bawls's Avatar
sounds like you've got a common high rpm miss. Check all plugs and wires, coil. etc.
Old Nov 9, 2004 | 04:11 PM
LoudmouthLT1's Avatar
What type of gas are you running? You might be pinging from to low of an octane rating, or there is possible detonation.
