383 Short block questions
Old Nov 9, 2004 | 02:26 PM
Script917's Avatar
Default 383 Short block questions
I was looking at strokermotor.com and found a few 383 LT1 short blocks. Here is what they have.
• Crank: New SCAT Cast Steel 3.750 Stroke 1pc rear seal
• Pistons: Keith Black Flat Tops 10.5 CR
• Rods: Scat 4340 Steel I-Beam, 6.0 w/ 7/16 Bolts
• Bearings/Rods & Mains: Clevite 77 'P' bearing
• Balancer/Pulley: Pioneer OEM elastic style 7" diameter
• Flywheel: SFI approved, 153 teeth
• Balance Job: High performance street/strip,
• Piston and rods matched +- 2 grams
• Please note that this kit sometimes need heavy metal when we balance it. This costs Extra.
$1,320.00
• Crank: 4340 Nitrided Steel 3.750 Stroke 1pc rear seal
• Pistons: SRP Flat Tops 11.1:1 CR
• Bearings/Rods & Mains: Clevite 77 'H' bearing
• Balancer/Pulley: Pioneer SFI approved steel 6 3/4" diameter
• Hub: Crankshaft flange hub for above balancer/pulley
• Balance: High performance street/strip,
$2,120.00
Should I avoid a Cast crank? If im building a 383 stroker with heads and cam hoping for around 450+hp. Will that cast crank cut it?
Also what is the max compression I can safely run with premium 91 octane fuel?
Old Nov 9, 2004 | 03:47 PM
GMC71k20's Avatar
those are just rotating assemblies, not an assembled short block
Old Nov 9, 2004 | 03:53 PM
Script917's Avatar
What exactly is a rotating assembly?
I know it’s a dumb question.
Old Nov 9, 2004 | 03:59 PM
LawmanSS's Avatar
"Rotating Assembly" usually denotes crankshaft, connecting rods, pistons, rings, and bearings...and in the case of those listed, flywheel and balancer.
Old Nov 9, 2004 | 04:07 PM
97M6Formula's Avatar
What he said so basically you would still need main caps and a few minor things for a complete shortblock as well as the machining done to your block APE is having specals right now on lt1 forged short blocks I would give em a call I got a good deal
Old Nov 9, 2004 | 05:44 PM
Snow Dog's Avatar
either one of those setups will work on 91 octane. the cast crank will handle 450 horsepower no problem. its the roms that you will have to wrry about. 6500 will be fine too with the cast crank
