Question on Cold Fusion Direct port nozzles!
I was wondering if anyone know if the Cold Fusion Direct port nozzles will work on a LT1 ? If so could I buy a traditional nitrous kit and then add the Cold Fusion direct port nozzles and lines to that kit. One last question, assuming the above mentioned worked could I use the new style NX MAXIMIZER with this system ??
I'm not sure if they make it for the LT1 or not ? That was one of my questions. The other thing I was trying to do was buy the dyno-tune kit for the LT1 ($399) and then use the direct port from Cold Fusion (8x$44= $352) and combine the two kits while using the NX Maximizer (new version) to control everything.
Yeah, I just talked to Cold fusion today and they said the direct port nozzles would work with the LT1, but they recommended using their noids if your mixing kits.
Oh yeah: Hi.....hi......hi BIG DAVE !
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
